Discussion topic: Locked Recordings being deleted
Message posted on 24 Apr 2023 11:43 AM
I have a SKY box which is around 98-100% full and shared by a number of family members in the house.
I know that at this level of usage new recordings will overwrite earlier ones but believed those identified as keep would not be deleted to make space for new recordings.
Can any one explain why recordings with' KEEP' status are randomly being deleted opposed to those without?
Also those without are not being deleted in oldest one first
Any explanation?
Message posted on 24 Apr 2023 11:50 AM
Re: Locked Recordings being deleted
Are they downloads or recordings from the TV Guide? Downloads from On Demand are automatically deleted once they expire.
KEEP does NOT override a programmes expiry date/time, the expiry is shown in the synopsis area (you may need to press the i button on your remote control)
Message posted on 24 Apr 2023 11:52 AM
They are recordings from TV Guide and not downloaded content
Message posted on 24 Apr 2023 11:54 AM
Thanks for comments - the recording are usually from BBC/ITV news/ topical shows so the deleted 'KEEP' ones are within 3-4 weeks of recording date
Message posted on 24 Apr 2023 01:32 PM
We've seen occasional reports before about recordings from BBC being deleted automatically. I don't think it has been established why. As recordings with the Keep indicator aren't deleted to make space for new recordings, I can only assume they're deleted at the behest of the BBC. I don't know what the reason is for ITV recordings being deleted, if they are.
Message posted on 24 Apr 2023 04:01 PM
@Mark39 Well, this has me confused. I always thought that it was the 'LOCK' option that prevented auto deletion not 'KEEP', but Google confirms that it is 'KEEP'.
So, what does 'LOCK' do?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 24 Apr 2023 04:04 PM - last edited: 24 Apr 2023 04:28 PM
Message posted on 24 Apr 2023 04:06 PM
Any explanation?
@germain123 Recordings that have been Viewed (even part viewed) should/would be deleted first oldest to newest then Unviewed oldest to newest.
Message posted on 24 Apr 2023 04:14 PM
I didn't know, but you made me curious. Apparently:
"You can lock programmes stored in your Planner to avoid them being
played back without your permission.
1 Go to your Planner.
2 Highlight the programme you want to restrict.
3 If necessary, press left/right until you can see the red option Lock.
4 Press the red button. A padlock symbol appears next to the
programme and you now have to enter a PIN to play or delete it.
You also need the PIN to remove the lock in future."
Message posted on 10 May 2023 09:40 AM
Hi Mark
Thank you for the comments which make sense considering earlier views
