9
This discussion topic has been answered Discussion topic: Accessing recorded shows on sky+ box
This message was authored by: JD18
I have recently upgraded from sky+ to Sky Q.  I would like to finish watching what I have recorded on my Sky + box but can't seem to get past the 'your box is innitiating' page.  Can anyone help?
This message was authored by: SKY1992bf Answer
Re: Accessing recorded shows on sky+ box
@JD18  Short answer is you can't as your access to the sky plus services has been cancelled as part of your switch to Q
This is not possible
Avatar for JD18
Hi, thank you for that.  Maybe I am being niaive but aren't the shows saved digitally on the memory of the box, and should in theory be accessable straight from the box?  Or did the engineer do something to the box to wipe it before disconnecting?  If he did, he should have said so when I told him I planned to keep the box to watch the saved shows.
Access to record/playback is via your viewing card and dish access, when you upgrade the dish is incompatible with Sky+ and your viewing card is disabled
Yes, recordings are stored on the hard disk of your Sky+ box. However, the box needs a signal from your satellite dish to do anything, and yours isn't receiving one - hence the initialising message. It's not receiving a signal because when you upgraded to Sky Q, the LNB on the arm of your was changed and the LNB for Sky Q isn't compatible with Sky+
Avatar for JD18
I see. Thanks Annie.
Avatar for JD18
Got it, thanks Mark.
Avatar for JD18
You two have been really helpful, many thanks.  One more question if you don't mind - is there a userguide online for the Q Box?  All I got from the engineer was a two-sided A5 card.
No, but the Help pages on the Sky website are intended to cover any queries.
https://www.sky.com/help/articles/welcome-to-sky-q
