Discussion topic: tv browser /sky max
This message was authored by: Diamante
tv browser /sky max
Just set up new sky max hub. Everything ok .BUT tv will not connect to internet  . It shows "server not found" and E106 . This is on everything .Security level shows WPA2  on app. I hace sky glass,but this is for second tv on sky puck .It worked fine just before I changed out boxes.
I really need to resolve this .Any ideas (not very tech savvy) ?
thanks
Avatar for Diamante
Re: tv browser /sky max
all sorted,but on tv browser it now shows error E107 on some sites .Anyone know how to fix this?
@Diamante Is there a reason that you think this is all down to the new skt Max hub or your new sky Connection that you have?
Avatar for Diamante
it only happend after i switched out old hub for sky max . Perhpas security feature?
