Discussion topic: sky sports
This message was authored by: phil-88
sky sports
I have skybroard band only. whats the cheapest way to get skysports?
Re: sky sports
If you only want to watch the sky sports channels, NOW TV is probably the best option.
Re: sky sports
@phil-88  now tv would probably be the cheapest as with other sky platforms you need the base package first as a pre requisite to adding anything else
Re: sky sports
@phil-88 Have you investigated the NOW TV App.  They offer free trials so you can see if it suits your requirements.
Avatar for phil-88
Re: sky sports
cheers.
Avatar for phil-88
Re: sky sports
cheers to all that have replied to me. 👍
Re: sky sports
Also with NOWTV during the last week of your first month cancel ... you are asked a number of questions answer all and you maybe offered a discount to further reduce the cost😉
You will also require the Boost membership for better picture quality🤔
Re: sky sports
If you have virgin broadband, then sky sports via virgin stream is currently cheapest option in the Uk. No base package required. £18.75 for all Sky sports channels in HD with full red button function. You very occasionally may get this slightly cheaper on Now Tv, although rare, common discounted price is £20 on Now, however this isn't full HD, which is extra and doesn't include the red button functionality for extra streams etc
