Discussion topic: sky puck wont activate
This message was authored by: Shetland_pony
I have reset it, turned it off and on, the usual stuff. When i get the code and enter it, it says check your sky glass, try again later,   I dont have sky glass, i only have the puck, can anyone help, the sky vurtial assistant is awful
Avatar for Shetland_pony
Re: sky puck wont activate
This message was authored by: 82bit
Try opening a private browser tab: go to sky.com/activate, login and enter the code.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband
Sky Mobile SIMO x7
how do i open a private browser ? all i want is to activate my account, it shuldnt be this hard
This message was authored by: Jlb77777
I have the identical issue currently, I have a call open with Sky and can see from other posts that this seems to be a pain to get Sky to fix! I will update you if it progresses.
This message was authored by: NorthernLass25
Hiya, did you ever get this sorted? I'm having the exact same problem now.
