Discussion topic: sky puck not lit up or sly working
Message posted on 04 Mar 2026 03:49 PM
hi i've not been able to use my sky TV since this morning the sky pick is connected however doesn't seem to be supplying the TV with anything Wi-Fi is also fully connected please help
Message posted on 04 Mar 2026 04:39 PM
Re: sky puck not lit up or sly working
@kelseybeaut wrote:hi i've not been able to use my sky TV since this morning the sky pick is connected however doesn't seem to be supplying the TV with anything Wi-Fi is also fully connected please help
The Stream puck needs the WiFi, not your TV. Is the correct HDMI input selected on the TV? Have you checked the HDMI cable is fully seated in both the puck and the TV?
Message posted on 04 Mar 2026 04:56 PM
i have and the
wifi is also commected - just not to the tv for some reason
Message posted on 04 Mar 2026 05:16 PM
@kelseybeaut wrote:i have and the
Why do you want the TV to receive WiFi too? Are there apps on it that you can't get on Sky Stream?
Message posted on 04 Mar 2026 05:19 PM
Message posted on 05 Mar 2026 09:46 PM
Having same problem
