Discussion topic: sky puck cable
Message posted on 02 Feb 2024 01:21 PM
sky puck cable
Hi, I have two tv's in a summer house for watching sport mainly. Do I need a separate ethernet cable for each puck ? A the moment I have one cable and a splitter wich doesn't want to work. Only one puck will work at one time. Both work separately as I have checked.
Any advice appreciated.
Message posted on 02 Feb 2024 01:58 PM
Re: sky puck cable
@hairybob wrote:Hi, I have two tv's in a summer house for watching sport mainly. Do I need a separate ethernet cable for each puck ? A the moment I have one cable and a splitter wich doesn't want to work. Only one puck will work at one time. Both work separately as I have checked.
What broadband speed to you get and what kind of splitter are you using? You really need an ethernet switch like this one in order to have multiple ethernet cables providing broadband to multiple devices.
You could always try using WiFi if it reaches your summer house.
Message posted on 02 Feb 2024 01:59 PM
Re: sky puck cable
Hi @hairybob
You would need to use a switch. The ethernet cable from your house / router to the switch and two other cables from the switch to each puck.
You can get them relatively inexpensively on Amazon: https://www.amazon.co.uk/Network-Hubs-Switches/b?ie=UTF8&node=430573031
Hope this helps.
MikeAlanR
Message posted on 02 Feb 2024 02:12 PM
Re: sky puck cable
Thanks for the quick reply, not being very tech savvy, i'm guessing a switch is a posh splitter ? Just to be sure, one cable from the router into the switch will run both pucks at the same time ?
Message posted on 02 Feb 2024 02:17 PM
Re: sky puck cable
@hairybob wrote:Thanks for the quick reply, not being very tech savvy, i'm guessing a switch is a posh splitter ? Just to be sure, one cable from the router into the switch will run both pucks at the same time ?
You would connect an ethernet cable from your router to the switch, then two more ethernet cables from any other ports on the switch to each puck.
Both pucks will then receive your broadband and should work as long as your broadband is fast enough to support it. Sky Stream needs around 25-30Mbps minimum for one puck.
Message posted on 02 Feb 2024 02:52 PM
Re: sky puck cable
Thats great, i'll shall try that. appreciate the help,
Live long and prosper.
Message posted on 02 Feb 2024 04:15 PM - last edited: 02 Feb 2024 04:16 PM
Re: sky puck cable
A 'switch' in this context is better understood as a multiplier, and permits numerous ethernet devices to be in use.
Although there are passive devices called an 'ethernet splitter' these won't do what you want: they 'split' a single gigabit eight strand cable into two separate four strand 100Mbs ethernet cables which is almost never actually appropriate.
Message posted on 08 Jun 2026 11:14 AM
Re: sky puck cable
Hi
If you had sky fibre ultrafast 950mbps and you wanted to have ethernet to every sky puck and not lose any maps.
I note that 100mbps is the max when 4 twisted pairs become 2 on ethernet cables, so does using a unswitched or switched (eg 10 way) give you the wired 950mbps to every device or is their another way to achieve the full 960mbps speed to all devices via ethernet?
Cheers
Message posted on 08 Jun 2026 11:28 AM
Re: sky puck cable
@Badgernow All pucks have 100mbps ethernet port as they really don't rrequire speeds above 50mbps MAX.
Message posted on 08 Jun 2026 02:31 PM
Re: sky puck cable
Thankyou.
Does it make a difference if I use switched or unswitched from a performance perspective?
Message posted on 08 Jun 2026 05:53 PM
Re: sky puck cable
An actual ethernet switch will almost always be preferable to nasty physical cable bodges.
