Discussion topic: pack box won't find wifi router
This message was authored by: hammer691
Message posted on 03 Jul 2025 11:42 PM
when searching for wifi router its not finding anything
This message was authored by: Dazzasky
Find out more
Message posted on 04 Jul 2025 01:20 PM
Re: pack box won't find wifi router
@james698henry wrote:
@hammer691 wrote:when searching for wifi router its not finding anything
Hello @hammer691,
If no routers are found, try toggling Wi-Fi off and on, ensure you're in range, and confirm airplane mode isn’t enabled. Restarting your device or resetting network settings may also help.
Best Regards,
James Henry
Stream boxes don't have airplane mode @james698henry
