4
This discussion topic has been answered Discussion topic: SKy Essentials TV & Full Fibre 500 with Netflix £40pm
This message was authored by: StitchUp
Hi all
I'm new to all this and only yesterday did I complete the setup of the package successfully 🙂
I believe I'm right in thinking that I should be able to watch Netflix on two devices (TVs). Presently my main TV is in the living room and I have one PUCK situated in the living room - all working.
Onto my question: If I wish to watch Netflix on the TV in my bedroom, what do I need to do? Do I need to purchase a 2nd PUCK - I don't have multi-room.
I look forward to any advice.
This message was authored by: BenJoBanjo Answer
Re: SKy Essentials TV & Full Fibre 500 with Netflix £40pm
@StitchUp wrote:
I do have an Amazon thingy attached to the TV with Netflix on it - would that work with the SKY login?
Yes, any streaming device with the Netflix app can be used. You just login to the app with the same email address and password you used when setting up your Netflix account.
@StitchUp Is the TV in your bedroom a Smart TV that has the Netflix app on it? If so, you shouldn't need another puck, you should be able to sign in using your Sky log in details for Netflix.
Avatar for StitchUp
I'm unsure tbh, I'll check shortly.
If it's not a Smart TV does that mean I'd need another PUCK? If so, do I buy from SKY?
Thanks a lot for the help 🙂
Avatar for StitchUp
