Discussion topic: pack box won't find wifi router
This message was authored by: hammer691
when searching for wifi router its not finding anything
This message was authored by: Dazzasky
Re: pack box won't find wifi router
@james698henry wrote:
Hello @hammer691,
If no routers are found, try toggling Wi-Fi off and on, ensure you're in range, and confirm airplane mode isn’t enabled. Restarting your device or resetting network settings may also help.
Best Regards,
James Henry
Stream boxes don't have airplane mode @james698henry
