1
This discussion topic has been answered Discussion topic: link for sky stream monthly not working
This message was authored by: stuart9999
i can't get link for sky stream monthly to work so can't purchase it
This message was authored by: Fothergill1 Answer
Re: link for sky stream monthly not working
Hi @stuart9999 unfortunately that will mean you having to cal the Sky Customer Service team.  If Sky is your mobile provider you can phone them by  dialling 150.
If it is not your provider follow this link https://www.sky.com/help/home and scroll down to need more help, click on this and you will see an 0333 phone number to use to call Sky. Unfortunately I cannot include the actual phone number as the forum filters will block it.
Answered - Go to Answer
