7
This discussion topic has been answered Discussion topic: White Light on Stream Box Now on Constantly
This message was authored by: HavencroftKev
As of today I've noticed the white light on my puck is now remaining on constantly, before when the puck was off the light was off.
Any ideas?
This message was authored by: Fothergill1 Answer
Re: White Light on Stream Box Now on Constantly
Hi @HavencroftKev  If you haven't already done so try unplugging it from the wall socket for a few minutes and then plug it back in again.  Allow it to reboot which will take a couple of minutes. Hopefully that will get it behaving correctly again.
This message was authored by: Dazzasky
Any ideas?
It sounds like the tv is not switching the puck off when turning off your tv @HavencroftKev you may need to re-pair it again
Avatar for HavencroftKev
Level 4 icon
The puck is turning off, on the screen at least.  It's just the light is staying on?
Hi @HavencroftKev
I have escalated your post to Sky. Keep an eye out for a blue chat bubble.
https://helpforum.sky.com/t5/Did-you-know/My-post-has-been-escalated/ba-p/3711147#M1014
This message was authored by: Brill+Gill
Posted by a Sky employee
Thanks for escalating this @Dazzasky. We’ve sent @HavencroftKev an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Level 4 icon
Thanks everyone, after swithching off at the wall for 30mins the Puck began behaving normally after the reboot.
This message was authored by: Jason-
Good Morning @HavencroftKev, it's great to see that your Puck has started working again after a reboot 🥳
If you do have any other issues then please do let us know here.
Cheers, Jason-
