This discussion topic has been answered Discussion topic: White Light on Stream Box Now on Constantly
Message posted on ‎25 Mar 2026 12:37 PM
As of today I've noticed the white light on my puck is now remaining on constantly, before when the puck was off the light was off.
Any ideas?
Message posted on ‎25 Mar 2026 12:43 PM
Hi @HavencroftKev If you haven't already done so try unplugging it from the wall socket for a few minutes and then plug it back in again. Allow it to reboot which will take a couple of minutes. Hopefully that will get it behaving correctly again.
Message posted on ‎25 Mar 2026 12:50 PM
Re: White Light on Stream Box Now on Constantly
@HavencroftKev wrote:As of today I've noticed the white light on my puck is now remaining on constantly, before when the puck was off the light was off.
Any ideas?
It sounds like the tv is not switching the puck off when turning off your tv @HavencroftKev you may need to re-pair it again
Message posted on ‎25 Mar 2026 12:58 PM
The puck is turning off, on the screen at least. It's just the light is staying on?
Message posted on ‎25 Mar 2026 01:22 PM
@HavencroftKev wrote:The puck is turning off, on the screen at least. It's just the light is staying on?
I have escalated your post to Sky. Keep an eye out for a blue chat bubble.
https://helpforum.sky.com/t5/Did-you-know/My-post-has-been-escalated/ba-p/3711147#M1014
Message posted on ‎25 Mar 2026 01:37 PM
Thanks for escalating this @Dazzasky. We’ve sent @HavencroftKev an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Message posted on ‎26 Mar 2026 06:25 AM
Thanks everyone, after swithching off at the wall for 30mins the Puck began behaving normally after the reboot.
Message posted on ‎26 Mar 2026 09:42 AM
Good Morning @HavencroftKev, it's great to see that your Puck has started working again after a reboot 🥳
If you do have any other issues then please do let us know here.
Cheers, Jason-
