187
Discussion topic: Watch from start fast forward issue once broadcast has ended
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Over the last couple of days i've noticed an issue with trying to fast forward a show once the broadcast has ended whilst using the "Watch From Start" feature.
The show plays fine with no issues but once the broadcast has ended, if you try to subsquently use fast forward it takes you back right to the start of the show. In fact you can't go past the point you got to without exiting the show and then loading it fresh from the playlist. Obviously this means you then have to know whereabouts in the show you got and fast forward to the point you were kicked out.
Any one else noticed this?
Sky Stream and Sky Broadband customer
This message was authored by KevNewMedia This message was authored by: KevNewMedia Answer
Re: Watch from start fast forward issue once broadcast has ended
Posted by a Sky employee
Hi Everyone
Thank you for your patience and perseverance whilst we worked through this technical problem.
Our support teams have advised that a fix will be deployed in the next firmware update, which is QS35.  We expect to start rolling out this release soon.  We understand your frustration and sincerely apologise for the delay in being able to fix this for you.
Kev
Community Manager
