Discussion topic: Wanting to add sky puck how do i do it
Message posted on 04 Sep 2025 03:25 PM
Hi. Iv got sky glass but want to watch sky in another room how do I do that as I can't find it anywhere thanks
Message posted on 04 Sep 2025 03:32 PM - last edited: 04 Sep 2025 03:34 PM
Re: Wanting to add sky puck how do i do it
@Donnamike2011 You should be able to do it through your Sky account, if not give Sky a call
Message posted on 04 Sep 2025 03:49 PM
@Donnamike2011 wrote:Hi. Iv got sky glass but want to watch sky in another room how do I do that as I can't find it anywhere thanks
What you need to do is add the Whole Home subscription to your package, along with a Sky Stream puck. Connect the puck to the TV in your other room with the supplied HDMI cable, connect it to your broadband and away you go. You'll be able to view all the same content you get on your Sky Glass TV on your other TV.
Message posted on 04 Sep 2025 03:56 PM
You can do it via: https://www.sky.com/mysky/tv/home-setup
You need to add the Whole Home pack to your subscription and you will also seem an option to select the number of additional Sky Stream pucks you want to order.
