Discussion topic: Wanting to add sky puck how do i do it
This message was authored by: Donnamike2011
Hi. Iv got sky glass but want to watch sky in another room how do I do that as I can't find it anywhere thanks
Re: Wanting to add sky puck how do i do it
@Donnamike2011  You should be able to do it through your Sky account, if not give Sky a call
What you need to do is add the Whole Home subscription to your package, along with a Sky Stream puck. Connect the puck to the TV in your other room with the supplied HDMI cable, connect it to your broadband and away you go. You'll be able to view all the same content you get on your Sky Glass TV on your other TV.
You can do it via: https://www.sky.com/mysky/tv/home-setup
You need to add the Whole Home pack to your subscription and you will also seem an option to select the number of additional Sky Stream pucks you want to order.
