1
This discussion topic has been answered Discussion topic: Waiting for programmes to load
This message was authored by: Jay1210
Just set up new puck. Loaded fine. Then  iturned it off and when I turned it back on get home page but when I try to access a programme, I get a message 'waiting to load programmes' or technical issue.
wifi connection all okay
This message was authored by: Angel_Aka Answer
Re: Waiting for programmes to load
Run a network check from the get help menu on the puck's Netflix app. This will give you an idea of the broadband speed actually being received by the device, not what an app tells you.
Also make sure network standby is turned on in the settings.
