Discussion topic: Volume and Mute Button
This message was authored by: Stephen+Mourton
I have read that some on here have problems getting their volume button to work.  Mine works fine but not how it should.
When I turn my tv and Stream puck on after it being turned off, the first time I use the volume button to mute the program it doesn't work first time, usually I have to press it a couple of times before it mutes, after that initial attempt it seems to work fine.
Has anyone else found this and is there a fix please?  Not that it's a major problem just an irritation.  Thanks.
