Discussion topic: Upgradinf from Sky Q to Sky Stream
Message posted on 04 Apr 2024 02:22 PM
Is it possible to upgrade from a Sky Q box + packages contract to 3 x Sky Stream boxes + same packagers contract?
Message posted on 04 Apr 2024 02:49 PM
Re: Upgradinf from Sky Q to Sky Stream
@Malcolm+LLoyd You would need to call Sky to discuss as we are all customers on the forum.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 04 Apr 2024 02:51 PM
@Malcolm+LLoyd wrote:Is it possible to upgrade from a Sky Q box + packages contract to 3 x Sky Stream boxes + same packagers contract?
Yes, but you'll need to ring Sky to do so.
Make sure you have a good enough broadband network to support 3 x Stream pucks and that you understand the different type of service Stream is. If you're a prolific recorder on Q then Stream may come as a shock...
Message posted on 04 Apr 2024 02:52 PM
@Malcolm+LLoyd Do beware aware the channel line up between q and stream is different, so make sure any channels that would be a dealbreaker are available
https://www.sky.com/help/articles/tv-channel-list-sky-glass
