Discussion topic: UHD and HD in the same playlist not possible
This message was authored by: tadstar
Hi looking for a solution to this which seems to be an issue which i cant resolve.
I have 2 TV's and 2 Stream pucks.  I want to have sport (football/F1 etc) in my playlist in UHD that i can watch on my UHD TV but also have HD versions in my playlist that i can watch on the other tv that is not HD.  There doesnt seems to be any way to do this. I either get only UHD version or only HD version in my playlist!
This message was authored by: Stephen+Mourton
Re: UHD and HD in the same playlist not possible
@tadstar  An interesting question.  It is something I've never tried but just tried it now and yes once you select the UHD version it won't let you select any other showings.  Maybe someone on here has found a way around it.  The only thing I can think of is to put the UHD version on your main box, then if you go to watch it on your mini box instead cancel the UHD program and select the HD version instead.
This message was authored by: best+of+the+best
Isn't it possible to add it from the tv guide for example select F1 UHD add that to your playlist then select F1 again but select other format and select F1 HD add that to the playlist or add each channel individually to your playlist Sky Sports F1 UHD Sky Sports F1 HD.
Avatar for tadstar
Unfortunately not ive tried that and I still get one or the other and not both. Ive even tried creating seperate playlists and tried to add uhd to one playlist and hd to another playlist but it doesnt work.
This message was authored by: Jamesmccaul
I wish this could happen as when I'm watching NFL some games are only shown half in UHD. So you just never see the first half.
