Discussion topic: Tv guide moved
This message was authored by: Nordiclaura
Tv guide moved
What's with the TV guide not being on the home page anymore?? Seems odd that its been moved.
Can you put it back on the home page please.
Re: Tv guide moved
@Nordiclaura It IS on the home page on Sky stream.
Avatar for Nordiclaura
Re: Tv guide moved
@GD1 Thank you for your reply. HOWEVER, on my home screen it has not and has been next to playlist as a tab.
Re: Tv guide moved
@Nordiclaura  Have you tried unplugging the stream puck then plug back in?
Re: Tv guide moved
Tv guide sits one section below Playlist.
Try saying 'tv guide' with your remote control. Another way to bring it up.
Re: Tv guide moved
@Nordiclaura There obviously was a problem as there is another post HERE where the poster reports a similar problem. Sky employee  @Kenny-J says the issue should be resolved.
