Discussion topic: Tv guide moved
Message posted on 08 Apr 2024 03:43 PM
Tv guide moved
What's with the TV guide not being on the home page anymore?? Seems odd that its been moved.
Can you put it back on the home page please.
Message posted on 08 Apr 2024 03:48 PM
Re: Tv guide moved
@Nordiclaura It IS on the home page on Sky stream.
Message posted on 08 Apr 2024 04:57 PM
Re: Tv guide moved
@GD1 Thank you for your reply. HOWEVER, on my home screen it has not and has been next to playlist as a tab.
Message posted on 08 Apr 2024 05:00 PM
Re: Tv guide moved
@Nordiclaura Have you tried unplugging the stream puck then plug back in?
Message posted on 08 Apr 2024 05:03 PM
Re: Tv guide moved
@Nordiclaura wrote:@GD1 Thank you for your reply. HOWEVER, on my home screen it has not and has been next to playlist as a tab.
Tv guide sits one section below Playlist.
Try saying 'tv guide' with your remote control. Another way to bring it up.
Message posted on 08 Apr 2024 07:48 PM
Re: Tv guide moved
@Nordiclaura There obviously was a problem as there is another post HERE where the poster reports a similar problem. Sky employee @Kenny-J says the issue should be resolved.
