4
This discussion topic has been answered Discussion topic: Trying to Factory reset my sky stream has bricked my remote.
This message was authored by: Eoghan96
I wanted to factory reset my Sky Stream so I could set up my soundbar properly (other options did not work). The first step was to unpair my remote, so I pressed 1 and 3 and the remote unpaired. The next step was to click 'continue' but I couldn't hit continue, as I had unpaired the remote. With no other options, I turned the puck off and on again. Now, the remote will not work. The batteries are fine, pressing 1 and 3, or 9 and 7 does nothing. Not sure what else I can do.
This message was authored by: lettice Answer
Re: Trying to Factory reset my sky stream has bricked my remote.
Try doing the following and holding for at least 3 seconds.
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue.
This message was authored by: Luke120
This has happened to me and can't reconnect remote this way
In the same circumstances? That is, you've carried out a factory reset of your Puck?
@Luke120
If you have tried the re pair of your remote as shown above and that still does not resolve the issue.
Have a look at this Sky Help article and try all that it mentions, and if still not helping, within that article you can order online a replacement remote.
Click on 'I still need help' button there
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remo...
