Discussion topic: There is a technical fault. Please try again later
Message posted on 16 Mar 2024 09:23 PM
As above. Thanks
Message posted on 16 Mar 2024 09:28 PM
Re: There is a technical fault. Please try again later
@Estich Have you tried unplugging the puck for a couple of minutes?
Message posted on 01 Apr 2024 09:16 AM
Hi, we have the same problem. It occurs across all 4 pucks and at its worst did not allow us into The Lazarous Project for a few days, eventually we just went to the next episode, which was the last one, and it worked. Also, occurred on ITVX but being a previously Amazon user this stream keeps dropping anyway. The problem also occurs on ITV1 on sky stream but this might be the same problem as ITV X.
As a final point it is dissapointing that Sky have cancelled Lazarous Project. Another really good scifi series gone!!
