Discussion topic: Technical issues on sky puck
Message posted on 03 Jul 2025 01:15 PM
Hello,
I have just received a new sky puck for my multi room
connected it properly, it doesn't allow me to connect to my internet via WiFi
plugged the Ethernet cable in.
Updated it all via Ethernet cable and then went to network settings and it's not allowing me to connect via WiFi
a little tricky to have it wireless in the bedroom
it says sorry because of a technical issue you're currently experiencing a limited service.
soon as I put Ethernet in it works, but I need it wireless
thanks
Message posted on 03 Jul 2025 02:22 PM
Re: Technical issues on sky puck
Sounds as if the wi-fi is struggling in your bedroom. Can you check the speed your receiving with your mobile in wi-fi mode in your bedroom. A work around is connecting your puck via a set of powerline adaptors.
