Discussion topic: Technical fault
Message posted on 02 Jul 2025 08:24 PM
Technical fault
Saying technical fault but WiFi is not working on the Tv and on the phones too .
Message posted on 02 Jul 2025 08:26 PM
Re: Technical fault
@Mrina7 Have you checked if your broadband is down?
Message posted on 02 Jul 2025 08:27 PM
Re: Technical fault
Yes, checked everything. This is going on and off for few days now .
Message posted on 02 Jul 2025 08:30 PM
Re: Technical fault
@Mrina7 Is that Yes your broadband is down? If so Sky stream won't work wthout broadband.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
