Discussion topic: Technical fault
This message was authored by: Mrina7
Technical fault
Saying technical fault but WiFi is not working on the Tv and on the phones too .
Re: Technical fault
@Mrina7  Have you checked if your broadband is down?
Avatar for Mrina7
Level 0 icon
Re: Technical fault
Yes, checked everything. This is going on and off for few days now .
Re: Technical fault
@Mrina7  Is that Yes your broadband is down?  If so Sky stream won't work wthout broadband.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
