Discussion topic: Technical fault
Message posted on 26 Feb 2026 07:16 AM
Technical fault
Hi all. I am getting fed up and extremely frustrated so I'm hoping someone cal help me please. Ever since I signed up with Sky over two months ago, I have had to regularly put up with the message that there is a technical fault and I should try again later. It's happening again right now! Can anyone advise a quick fix or how I can get through to the right people at Sky without spending half a day on the internet? You would make an old man very happy, which Sky certainly are not doing right now! Thanks in advance.
Message posted on 26 Feb 2026 07:29 AM
Re: Technical fault
@Adaldan wrote:Hi all. I am getting fed up and extremely frustrated so I'm hoping someone cal help me please. Ever since I signed up with Sky over two months ago, I have had to regularly put up with the message that there is a technical fault and I should try again later. It's happening again right now! Can anyone advise a quick fix or how I can get through to the right people at Sky without spending half a day on the internet? You would make an old man very happy, which Sky certainly are not doing right now! Thanks in advance.
Hi @Adaldan
You've posted in the Sky+HD Forum, which I suspect you don't have.
Do you have Sky Q or Sky Stream?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 26 Feb 2026 07:35 AM
Re: Technical fault
I thought I had Sky+ but maybe I'm wrong. I'll have a check again. Sorry, only just joined Sky so still a little unclear.
Message posted on 26 Feb 2026 07:36 AM
Re: Technical fault
Sky+ hasn't been offered by Sky for a good while now so if you've only just joined you won't have that.
Does your Sky use a satellite dish?
Message posted on 26 Feb 2026 08:22 AM
Re: Technical fault
@Adaldan sounds like you may have Sky Stream which works from a small square set top box?
Message posted on 26 Feb 2026 01:09 PM
Re: Technical fault
That's right, thanks.
Message posted on 26 Feb 2026 01:10 PM
Re: Technical fault
No it doesn't. I believe I have sky stream.
Message posted on 26 Feb 2026 01:56 PM
Re: Technical fault
@Adaldan wrote:No it doesn't. I believe I have sky stream.
You need to make sure your home broadband connection is as fast and stable as possible. Sky Stream relies entirely on you having a decent broadband network, free of interference or speed fluctuations, otherwise you'll keep receiving error messages.
Have you rebooted your router recently? What speed is your puck receiving? Run a network check from the get help menu on the Netflix app to get some idea of what speed is being received. You need a sustained speed of 25Mbps otherwise SkyOS can struggle.
Message posted on 26 Feb 2026 04:04 PM
Re: Technical fault
Thanks, I'll try those steps. I've actually got broadband through Sky as well.
Message posted on 26 Feb 2026 04:45 PM
Re: Technical fault
@Adaldan wrote:Thanks, I'll try those steps. I've actually got broadband through Sky as well.
Who you have your broadband with doesn't necessarily matter. Most ISPs, by default, will only guarantee the speed to your router; they won't guarantee WiFi speeds throughout the property (although some ISPs do offer upgrades that include a WiFi speed guarantee). This is mainly because there are numerous factors which can cause Wifi interference (coupled with the fact that some ISPs provide fairly cheap routers to customers).
