Discussion topic: Technical fault
This message was authored by: Ash62
Technical fault
Have turned off puck and broadband and back on again all we get is the home page no channels says technical fault try again later Wi-Fi on all other devices is working ok. Ash
Re: Technical fault
@Ash62  How is the puck connected to your hub as this is likely a wifi related issue.
This message was authored by: Ifu03440
Re: Technical fault
Are you with hypertonic broadband?
