Discussion topic: Technical fault when trying to get mainstream tv like bbc
This message was authored by: Stewart12
Re: Technical fault when trying to get mainstream tv like bbc
@Stewart12  Welcome to the forum.
I would try resetting your puck by going into Settings > System Management > Resets & Updates > Restart device (do not do a factory reset).  It takes about 3 minutes to completely reboot. You will have a blank screen for part of the process so don’t panic.
This message was authored by: Ifu03440
@Stewart12  Who is your broadband provider?
