4
This discussion topic has been answered Discussion topic: Technical fault with this programme
This message was authored by: extravagance
Since Christmas Eve and only since Christmas Eve the sky pucs (I have 3) are all displaying error codes when trying to watch any of the channels such as 101,102,103 etc - the apps work perfectly - the issue is just with what I'd call the terrestrial  channels - so frustrating - anybody experiencing the same? I get the following issues,
1. The channel loads and displays a black screen with the message "please wait while the programme loads"
2. while watching a channel we get a channel crash and now screen or "there's a technical fault with this channel"
I've tried updating the puc, restarting etc - the fault remains
anybody experiencing the same manage to find a solution?
Avatar for extravagance
This message was authored by: extravagance Answer
Re: Technical fault with this programme
So, even though my wifi is good, it seams the sky puc prefers a wired connection directly to the router - after doing this it clears the problem.
cheers
This message was authored by: Jporch316
Have you tried fully rebooting your router and sky pucks?
Better terms would be PSB or FTA channels depending on the specific channels ... even though you need a subscription to watch any channel on Sky Stream😉
Would suggest trying a restart of your Sky Stream box
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
cheers
