Discussion topic: Technical fault on all chanels
Message posted on 18 Feb 2025 06:22 AM
Why is my Sky glass and stream unable to connect when I can stream sky through my ipad? I seem to remember this happening before.
i've rebooted evereything but believe this a firmware issue between Sky and Virgin media.
Message posted on 18 Feb 2025 06:27 AM
Re: Technical fault on all chanels
Would suggest trying a restart of your Sky Stream box
On your puck
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Message posted on 18 Feb 2025 09:40 AM
I did a restart, factory reset. BBC worked for a while but then problem reoccurring
