Discussion topic: Technical fault keeps showing
Message posted on 28 May 2025 10:15 AM
My sky tv keeps coming up with Technical fault with this programme on all channels and recoded programs. Does anyone know why. This seems to started happening after having Sky Fibre 300 connected for WiFi? The only way I can get rid of this is to turn off everything including WiFi hub and then reconnecting but this takes ages and I then have to reconnect everything including WiFi hub the house also Hive? I am at my wits end with frustration. Elaine
Message posted on 28 May 2025 10:19 AM
Re: Technical fault keeps showing
Is this on Sky Q, Glass or Stream ?
Message posted on 28 May 2025 10:35 AM
Hi it is on all channels on normal sky
Message posted on 28 May 2025 01:21 PM
That doesn't answer my question @Elaine+Mason ?
Do you have Sky Q, Glass or Stream from Sky ?
Message posted on 28 May 2025 01:42 PM
Stream from sky
Message posted on 29 May 2025 09:39 PM
@Elaine+Mason wrote:My sky tv keeps coming up with Technical fault with this programme on all channels and recoded programs. Does anyone know why. This seems to started happening after having Sky Fibre 300 connected for WiFi? The only way I can get rid of this is to turn off everything including WiFi hub and then reconnecting but this takes ages and I then have to reconnect everything including WiFi hub the house also Hive? I am at my wits end with frustration. Elaine
Hi Elaine
sound like a WiFi signal is not strong enough. Can you try connecting the puck to the router with an Ethernet cable (whilst turning off WiFi in the puck settings )
If the you don't get the issue anymore then your wifi signal is strong / consistent enough
Message posted on 29 May 2025 09:56 PM
Hi I have just had sky fibre 300 fitted and I keep checking the strength of the signal which seems to be ok and everything else in the house is working fine. I wonder if my Sky q box has become faulty. I will try your suggestion though. Thanks
Message posted on 29 May 2025 10:06 PM
Stream is a little more sensitive to wifi inconsistencies than other devices .......
