Discussion topic: Technical fault - 7 (33) affecting recordings
This message was authored by: tahnontour
For the last 2 months many of the programmes we've tried to record have shown this error message. Anyone know what it refers to, and more importantly how to combat it? The recordings always have a lack of signal interruption within them.
Re: Technical fault - 7 (33) affecting recordings
@tahnontour
Are you a Sky+ customer ?
@tahnontour yes that's a Sky+ box and the fault indicates a hard disk problem.
You could try a Planner Rebuild and if that doesn't help, a full system Reset. This guide explains how.
If neither resolves it, your hard disk is failing, I'm afraid, and you'll need to upgrade either to Sky Q or Stream.
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
My FAQ also has the FSR instructions 🙂
