Discussion topic: Sky box not working
This message was authored by: Eddiemun1
Sky box not working
One of my sky boxes stopped working
Re: Sky box not working
Explain further
This message was authored by: liz+ferrie
neither is mine  ,, firstly no sattelite signal,,then it has been initialising  for over half an hour
@liz+ferrie if your Sky box isn't receiving a signal from your satellite dish,  it can't initialise. Try restarting the box by switching it off at the plug for 5 minutes. If that doesn't resolve it, the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
it s came back on,,,,i ve had this happen a couple of times when it rains
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
