Discussion topic: Technical Fault
This message was authored by: HiteshVadolia
Technical Fault
I keep getting the message of Tech fault on TV - TV puck was recently changed so now I think it's an issue with the router. Broadband connection to the house it fine as per the tests online. The router to TV is not connecting it keeps fluctuating and the picture keeps freezing or shows technical fault message.
Re: Technical Fault
@HiteshVadolia
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
▪️I AM NOT A SKY EMPLOYEE ▪️
