Discussion topic: Technical Fault
This message was authored by: HiteshVadolia
Message posted on 18 Jul 2026 10:05 PM
Technical Fault
I keep getting the message of Tech fault on TV - TV puck was recently changed so now I think it's an issue with the router. Broadband connection to the house it fine as per the tests online. The router to TV is not connecting it keeps fluctuating and the picture keeps freezing or shows technical fault message.
Find out more
Message posted on 19 Jul 2026 04:18 AM
Re: Technical Fault
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
▪️I AM NOT A SKY EMPLOYEE ▪️
