Discussion topic: Tech fault try later
This message was authored by: Amanda19841
If when i click on sky channels it says technical fault try later.
Can't watch any sky channels or live tv. No recordings.  But can open Netflix
Re: Tech fault try later
Netflix????? Do you have Sky Q or Sky Plus?
Avatar for Amanda19841
I think sky plus. But I don't know
If you have Sky Plus then Netflix does not come into it as you must be using this via other means as Sky Plus cannot run apps
What does the actual error message say?
Sly stream
I have moved your thread to a more appropriate forum
