Discussion topic: TV guide and programmes disappeared
Message posted on 09 Oct 2025 12:01 PM
08.10.25 SKY stopped working properly.
My tv stopped showing live tv.
The guide just disappeared. Is there a problem with SKY?
Apps worked fine but no bbc etc channels were showing on my guide.
8 th oct 2025.
Was this a problem in the uk?
Any one else affected by this?
Samsung tv. Sky Q box.
Message posted on 09 Oct 2025 12:33 PM - last edited: 09 Oct 2025 12:35 PM
Re: TV guide and programmes disappeared
This was fixed about 2215 yesterday (roughly). Can't quite make that image out but it doesn't look like a Sky Q box.
Message posted on 09 Oct 2025 12:53 PM
You've also posted on the Stream thread so is that what you have?
Message posted on 09 Oct 2025 01:22 PM
Thanks ... sky+ box!
Message posted on 09 Oct 2025 02:12 PM
@MKam wrote:Thanks ... sky+ box!
It's not a Sky+ box, it's a Sky Stream puck.
Message posted on 09 Oct 2025 02:28 PM
first time using ... i only put the picture in as it would not let me submit question until i added more. its a box from sky, wierdly, most people are only interested in my misnaming the device. interestingly none were that helpful regarding the outage.
Message posted on 09 Oct 2025 02:31 PM
We were trying to establish which platform you subscribed to so your post could be moved to the correct place. It started in Sky Q, then you said you had Sky+ so it was moved and now we've confirmed it is a puck it's been moved again.
The original reply is still correct. The issue was fixed yesterday evening.
