7
This discussion topic has been answered Discussion topic: Synching Sky Stream remote to control Amazon Fire TV
This message was authored by: mnewm
Just switched from Sky Q to Sky Stream. I am unable to link the new Sky remote control to turn to on/off and amend the volume. Any suggestions?
This message was authored by: Scottyboy999 Answer
Re: Synching Sky Stream remote to control Amazon Fire TV
Hi i have recently had this problem, i then put the manufacturer as JVC and it worked on the 2 or 3rd attempt. Hope this helps.
This message was authored by: Ellie_TV
Is your TV one of the Amazon Omni QLED sets or is it manufactured by another brand and uses the FireTV OS?
Avatar for mnewm
I believe it is an Amazon branded unit
Avatar for mnewm
@Scottyboy999 Worked a treat - albeit after 14 attempts x
This message was authored by: shadow971959
I have the same issue, tried ll manufacturers nothing, fire tv code not accepted or cannot be found
This message was authored by: Jporch316
Is it a tv or firestick ?
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
yes a tv
Answered - Go to Answer
