3
This discussion topic has been answered Discussion topic: Switching on Sky Stream
This message was authored by: AndyM5
Hi, I have a new small LG 32" tv in the bedroom connected to a puck but when switched on it defaults to the LG interface, I then have to navigate to the hdmi 1 icon to get the stream interface. Any ideas on how I van just get the stream to be the default interface?
This message was authored by: mikealanr Answer
Re: Switching on Sky Stream
Hi @AndyM5
Yes. When the puck is on standby home should wake the puck and in turn your TV. To turn off long press the power button.
MikeAlanR
Hi @AndyM5
Look for a setting in your TVs menu around CEC control. If enabled this should allow the puck to wake the TV up and set it to the correct output.
MikeAlanR
Avatar for AndyM5
Thanks Mikr,
  • I've found & enabled it on the LG settings & it seems to have worked albeit to turn the tv on I have to press the home button on the sky remote to get the sky interface, is this the correct way ?
Hi @AndyM5
MikeAlanR
