Discussion topic: Swapping Sky Glass for normal tv
This message was authored by: philww40
Hi
I currently have a sky glass tv and then a puck in the kitchen with a normal tv.
The picture quality is so much better on the normal tv rather than the sky glass.
If I go back to a normal tv rather than glass  does that mean I have to go back to sky q and have a box again??
I'm totally confused!
Re: Swapping Sky Glass for normal tv
No, you would simply need another Puck (to connect to the tv replacing the Glass).
This message was authored by: Ray7162
so is the puck the actual streaming part
to be clear if i ditch sky glas stv and go back to a normal tv are you saying i just need to attached a normal tv to the puck and will i still get playlsit etc etc
Yes, that's correct. Sky Stream is the same streaming service that you get on Sky Glass, just on any TV with a Sky Stream puck attached to it. The puck has the same SkyOS which runs on Glass and receives the same Sky content via your broadband that you get on Glass.
Great so ig i switch tv i simplhy plug one of my pucks into the new tv and off we go??
Yup. If you have multiple pucks then you'll still need the whole home subscription to have them all function.
