Discussion topic: Stream sound drop on atmos uhd hdr
This message was authored by: purpleparrotuk
Every time I watch a show on any sky channel that's in UHD HDR and Atmos, I will always get a sound drop once in the show at random times. I have read various posts on here and tried everything. I have changed all my HDMi cables to certified 2.1 ones. I have a Sony AF9 tv and a Denon 3700H av receiver. I've tried the stream going into the av receiver and also tried the stream direct to the TV using ARC and Earc. Every time the sound cuts out just for 1 second. This has been on Lazarus Project, Breeders and now Last of Us. It's really annoying I can't fix this and guess I never will 😞
Re: Stream sound drop on atmos uhd hdr
Have you tried requesting a replacement Sky Puck?
Avatar for purpleparrotuk
Level 7 icon
@Exiled-in-HH Do you think it could be dodgy then? I swapped my puck upstairs and it still did it.
So it happens on two Pucks.... and the Pucks work OK when not connected to the Denon device?
Level 7 icon
@Exiled-in-HH I'm guessing the puck either doesn't like the tv or the Denon. There must be other people with these devices though. Maybe I will post on my tv/hifi forums.
Do you get sound drops when either Puck is connected to the TV without the Denon device?
Level 7 icon
@Exiled-in-HH I cant test that. My tv has no speakers.
How did you get the speakers removed from your Sony AF9 TV?
Level 7 icon
@Exiled-in-HH they are built into the stand. You remove the stand when you wall mount it. I now have a 5.1.4 Atmos speaker system.
You could reconnect the TV's speaker to determine whether you get sounds drops without the Denon device!
Level 7 icon
So it's not my system it's just the pucks that can't cope. Watched the Last of Us on my bedroom setup. LG soundbar and Sony tv and the sound dropped out once in the show too.
Will try just watching in UHD since hdr doesn't seem to improve the picture anyway.
Level 7 icon
@Exiled-in-HH @I wont be taking my tv off the wall to attach the speakers and base. It will take hours and took me ages to get the angle right. It seems I don't have to and it's just the pucks that can't cope.
If your confident it is the Pucks you could try replacing them🤔
Level 7 icon
@Exiled-in-HH Because I think they will all do it. I am sure not many people watch stream in uhd hdr with full atmos surround and that's why not many people have reported the problem on here. I will call Sky at some point and see what they have to say.
Sounds like the best course of action😟
