Discussion topic: Stream - slow and laggy
This message was authored by: wdhayden
I do love my Sky Stream now... but I do find it often gets very slow and laggy when navigating the menu's and TV guide.
I've got wired broadband at 900mb plugged in.
is it like this for everyone?
Re: Stream - slow and laggy
@wdhayden
UI speed can vary. It depends on server and local network congestion. SkyOS is almost entirely server-based, very little occurs on the actual puck itself, so everyone's experience is different depending on how their own puck is connected to their individual broadband network and the Sky server their puck is assigned to.
Avatar for wdhayden
Ah ok. Thanks for your reply.
I do notice when I switch off at the plug, then on again, it goes back to normal... but after a day or so, goes back to laggy and slow again.
Doing a full reboot, either by turning it off at the plug or by doing a restart from the settings menu can help because it flushes the cache and re-establishes the server connection. Doing this regularly, every few days for example, can help to keep the UI a bit more fluid and less laggy.
This message was authored by: Bluegiraffe
Yep - this came in during a software upgrade a while ago, it was reported - we we were told it was 'fixed' but it's not...I have the same as you. As for the server comment above - I would be horrified if at least some of the data is not at least cached locally.
But as stated - this is a regression...and an annoying one at that.
Sky OS 1.3
Build: QS37.045.01P
Bluegiraffe
Ammendment - UI version 3.33.0
