Discussion topic: How do I wifi settings to my puck after needing to use an ethernet cable to set up my puck ?
Message posted on 13 Oct 2025 07:27 AM
I received my puck and it would not connect to wifi , as soon as I put it on it said " updating ". After speaking to a sky tech help I had to use an ethernet cable. How do I add my wifi settings? I don't want to continue using the ethernet cable. Thanks
Message posted on 13 Oct 2025 10:21 AM
Re: How do I wifi settings to my puck after needing to use an ethernet cable to set up my puck ?
Hi @Hendie3 and welcome to the forum. I did exactly this a few weeks ago and I did the following.
1. Go to the Settings > Network > Advance settings menu and turn on the WiFi toggle.
2. Unplug the Ethernet cable from both your stream puck and your router
3. Go back to the Network menu and select Network connection. You can enter your network name and password here.
Once you have done the steps above reboot your puck.
Good luck.
