Discussion topic: Stream not working
This message was authored by: Nitram47
Message posted on 23 Oct 2024 06:43 AM
Stream not working
Keeps stalling. Message says technical fault and wait to load programme
Find out more
Message posted on 23 Oct 2024 07:38 AM
Re: Stream not working
Hi @Nitram47
Usually points to poor broadband speed or quality of connection between puck and router. Sky Stream needs 25Mbps for HD and 30Mbps for UHD. You can check the speed your puck is getting by opening netflix going to get help and running a connection check.
You could try using an ethernet cable or homeplugs to improve stability (and turning WiFi off in the puck settings). Or using a booster if your WiFi signal is marginal.
MikeAlanR
