Discussion topic: Stream Puck remote
Message posted on 18 Jun 2024 11:56 AM
Stream Puck remote
Hi, Has anybody else had issues with their Sky Glass remote for the Streaming Puck?
Message posted on 18 Jun 2024 12:39 PM
Re: Stream Puck remote
@GRAYST wrote:Hi, Has anybody else had issues with their Sky Glass remote for the Streaming Puck?
There have been many, many posts about problems with the remotes on Glass/Stream since they launched. Various issues from exploding batteries to lack of Bluetooth control to complete failure for no logical reason.
Follow the troubleshooting here and if it doesn't help you can order a replacement under warranty:
https://www.sky.com/help/articles/remote-control-help-sky-glass
Message posted on 18 Jun 2024 01:10 PM
@GRAYST Welcome to the forum. To help you try to get your remote working the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it works more often than you would think and has got my remote working again on 2 occasions.
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
