Discussion topic: Stream Issues
This message was authored by CF79 This message was authored by: CF79
Re: Stream Issues
This is frustrating.  I've just returned to sky after getting a deal with broadband.  Thought stream would be a good option.  We've had the box 4 hours.  It has powered itself off twice,  become non responsive to the remote several times and now glitching and frozen trying to watch Disney.  The only way to correct is to power off.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Stream Issues
Do you have it connected to the internet via WiFi? If so I'd suggest trying to disable the WiFi via the pucks settings and connecting via an Ethernet cable and see if that helps.
it's also worth opening the Netflix app on the puck go to get help and check your network. This will show the download speed the puck is getting. Best trying this when you start to see freezing issues.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
Re: Stream Issues
Connected by Ethernet.  Connection speed 65Mbps. I've now disabled WiFi as well.  Disney just crashed again after about 3 seconds.
Re: Stream Issues
Yeah disabling WiFi is a good thing as it keeps switching between the 2 otherwise.
its possible the reboot now will help, i know i had to reboot when i disabled WiFi for it to take affect.
is it only Disney + that does this? If it is perhaps trying an app refresh will help.
Settings > System Management > Resets & Updates > refresh apps. This process is not instant and is carried out in the background so don't expect an instant solution.
NOT a Sky Employee
This message was authored by Anonymous This message was authored by: Anonymous
Re: Stream Issues
Well, I was considering switching to Stream from Q when I do the annual dance in May but you lot are putting me right off.
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Stream Issues
If you haven't already try connecting via WiFi ..... you never know you could have a dodgy ethernet cable. Providing you have a good signal strength where your puck is located you may be surprised......
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Stream Issues
As others have noted, the Sky Stream experience can be somewhat glitchy. Some days it works fine, others it can be a right pain. Regular rebooting at the socket is pretty much inevitable - it shouldn't be, but it is.
Some have a better experience than others but I think most people feel the pucks could do with some hardware improvements to make them more stable. Hopefully that'll happen at some point... but probably not soon.
Re: Stream Issues
Weren't the Stream boxes first launched about a year ago in Germany or do they use different hardware?
Re: Stream Issues
The Stream pucks were launched in the UK more than two and a half years ago in Oct 2021, at the same time as Glass. They became available as standalone devices a year later in Oct 2022.
They are based on the Comcast XiOne boxes launched in the USA around the same time.
Comcast have also recently just launched the Xumo Stream Box which is the same hardware again with a different remote, but this time running a variant of the same Entertainment OS we have on the Stream puck. It's not exactly getting glowing reviews in the states either...
Re: Stream Issues
Ahh, of course, I'd forgotten the Glass multi-room pucks. I've still got a pending order of a Glass TV from Oct 2021 on my account as I cancelled it before it arrived and broke their system 🙂 Took me forever to get the refund too.
Re: Stream Issues
We've done several reboots and still having the same issues.
I've tried a different ethernet cable direct to the router with no other devices wired and still havng the same issue.  Netflix shows 90Mbps speed.  We rebooted it last night while watching something else via another device.  After about 15 minutes we tried the Sky puck again but it was non responsive after not even using it.  I can't believe it is this bad for everyone, but seems like some level of issue is very common.  I asked yesterday for a Sky Q box instead, but they don't provide them anymore.  I'm very relucatnt to continue into a 18 month contract with this product.  Added to my issues is Sky incorrectly opening my new account under my wifes name.  Seems like because I used an existing userid on Sky.com they have reactivated our old account.  Thus when I ask to cancel this new contract they are saying they can't as they need to speak to the account holder.  Frustrating would be a polite way to describe the situation.
Re: Stream Issues
I sympathise with your frustration.
Whoever told you that Sky Q is no longer provided is mistaken. You can absolutely still order Sky Q. If you really still want a Sky subscription then you should get back in touch with them and ask to speak to someone who knows about Q.
Re: Stream Issues
Following further discussion we decided to cancel the service.  Sky were requiring me to contact my ISP to ensure there was no issue with my broadband (When every other device in my house works fine) and then suggested that I change the password on my router to see if that worked (connected by ethernet anyway).  When we proceeded to cancelling my Wife had to verify her ID, but then had to give my email instead of her own as it was me that opened the account.  Just a ridiculous state of affairs.  Then we've had an email stating we will be charged for the time we had the service.  I've cancelled the direct debits as no way am I paying for the unusable service we've had.  Really disappointing service from Sky.
This message was authored by WogerB This message was authored by: WogerB
Re: Stream Issues
@Dunlop73 Did you receive your replacement Sky Stream Puck? I've had all of the same types of problems, tried all of the fault finding suggestions and gave up. I spoke to Sky on 9th February and they said they would send me a replacement puck. Called them again on 15th as I'd heard nothing and they said it could take up to 10 working days. Here we are 13 working days on and not a peep out of them.
This message was authored by Mikeabc1 This message was authored by: Mikeabc1
Re: Stream Issues
Had Sky in its various guises forever and was fine with Sky Q. I was there increasingly using streaming services and Apple TV and wanted to go full streaming and get rid of the satellite dish and Sky Q hardware.
I've got 2 rooms with TV. One is a media room with a full Sonos setup and Apple TV and the other in the lounge  with Sky Soundbox.
Initially I went with Sky Glass but as soon as it arrived I hated it and switched to a new 4k TV in the media room and Sky Stream on both.
Its fair to say it was not an easy switch from Q but I'm now sold on streaming.
From the off I had massive problems with the puck in the lounge. These have now largely disappeared, partly as a result of settings changes and some I suspect with software upgrades to the puck.
Oddly I have never had an issue with the one in the media room.
If you are wedded to the idea of watching recorded programmes then stick to Q, but I have to say I am now happy that I made the switch. I've got my head around advert skipping and have not to reboot for about a month.
I'm watching 4k on an 83" 4k TV with no problem on a 35MPS feed whilst simultaneously watching HD on the lounge TV. In a 3 storey Victorian house so have the router on the middle floor so it only has to punch the signal through the floor to the lounge or ceiling to the media room. No thick walls.
Hope this helps.
