Discussion topic: Sound keeps cutting out on stream
Message posted on 23 Dec 2024 04:15 PM
I am having to reset my sky puck most days as the sound keeps cutting out! Surely this isn't something which should happen regularly, is there a permanent fix for this? Rather than having to reset most days?
Message posted on 23 Dec 2024 04:43 PM
Re: Sound keeps cutting out on stream
@Mari401 wrote:I am having to reset my sky puck most days as the sound keeps cutting out! Surely this isn't something which should happen regularly, is there a permanent fix for this? Rather than having to reset most days?
What are your audio settings on the puck? Auto, passthrough, Dolby Digital, PCM?
Are you using the HDMI cable that came with the puck to connect to your TV?
Are you using a soundbar or AVR?
Message posted on 23 Dec 2024 08:16 PM
I'm using the HDMI that came with the box
Message posted on 24 Dec 2024 10:08 AM
I've moved the puck closer to the modem and it's still not making a difference..any ideas??
Message posted on 05 Jan 2025 09:44 PM
We are having same problem. But only on sports and cinema channels.
Message posted on 05 Jan 2025 10:12 PM
We ended up changing our puck as the problem never really got resolved! It's been okay with the new one so far...
