5
This discussion topic has been answered Discussion topic: Sky streaming changing channels on its own
This message was authored by: pie2
Watching sky streaming channels the channels are changing without any input from me and remote doesn't seem to work
Avatar for pie2
This message was authored by: pie2 Answer
Re: Sky streaming changing channels on its own
Thanks for this.  I will keep it in mind but the problem seems to have resolved itself without any action from me.  Interesting that only happened with the smart tv but the other 2 ordinary tvs are fine.
This message was authored by: Stephen+Mourton
@pie2    Just to be clear,you do not have a problem with getting a picture and sound, it is just that the remote doesn't appear to work and Stream keeps changing channels by itself?   If your remote is not working how do you turn the tv on and off?  Also can you increase or decrease the volume with it?
This message was authored by: Jporch316
Have you tried pulling the plug for a few minutes ?
also if you pull the batteries from the remote once on a channel does the issues still occur
As above a power or puck settings restart often cures this.
It could also be a stuck remote button or pairing inconsistency.
If after the reboot has not fixed it, try re pairing your remote control
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue
More info here and a form to request a replacement remote, by clicking on 'No I still need help';
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remote/ar...
This message was authored by: Nigelb1972
I'm going to hazard a guess that somebody has spilt something on the remote at some point, most probably fizzy pop, beer or wine. They've preceded to clean it but forgot about the liquid that went inside the remote. The sugar in the liquid is now causing internal damage to the remote resulting in failure and random channel selections...
Avatar for pie2
Answered - Go to Answer
